CR80 Remote Peeves?
Discussion in 'Arcam Owners' Forum' started by radio, Jun 11, 2005.
Tags:
  1. radio
    radio
    Jun 1, 2005
    246
    Toronto, Canada
    +5
    Hiya,
    My AVR300 is a day old now and its truelly become a delight. I had my father over to give it a listen and he was fairly pleased, he seems to have as much of a keene ear as i do... I guess it runs in the english blood :D.
    In any case i have set everything up the crossovers set to 50hz, the component output and inputs are set... i have no desire for 7.1 setup so 5.1 it is.
    Towards the end of the night last night i tackled the remote control and i have a few questions/comments for the more experienced cr80 users out there.
    - I find it a bit odd that when u select source (amp + sat) you are in dvd mode at that point the volume does not work for the avr300 u have to click amp again to use the volume. I did give the volume lock a look i tried and it didnt work? maybe i did something wrong?
    - another issue which i suspect may be for the avr300 is that when i switch sources e.g a lot many times i would be watching news tickers on tv and listening to music so i would hit cd. when i do so it resets the display and brings it back instead of not touching the display at all. In the menu i tried setting it to "none" at that point gives me a blank screen.
    I am not too concerned about the video reset issue i am mostly kinda peeved about the volume setting as i tend to adjust the volume a lot.
    I was even considering spilling a few hundred dollars on the Harmony 880 and it may not have similar issue?
    ThanX in advance.
  2. will1066
    will1066
    Dec 10, 2004
    103
    +9
    Just to share, I also cannot adjust the volume when the remote is set to DVD mode. The player is a Denon 2900.
  3. Greggles
    Greggles
    Mar 15, 2005
    1,070
    St. Saviour, Jersey
    +74
    I take it you guys have set the Volume Lock to Amp (p11 of CR80 manual)
    Press and hold (SET) until the LED blinks twice
    Enter 9 9 3 and then press (AMP)
    The VOL+, VOL- and MUTE buttons should now work the AMP, irrespective of the selected source.
  4. radio
    radio
    Jun 1, 2005
    246
    Toronto, Canada
    +5
    Thanks a bunch it seems to work... i did look over page 11 but it seemed that i misunderstood the para on volume lock.
    It works like a charm.
  5. will1066
    will1066
    Dec 10, 2004
    103
    +9
    Works like a charm for me too. Thanks, Greggles!
  6. Starkiller
    Starkiller
    Nov 3, 2003
    202
    +3
    good tip, nice one
  7. espenf
    espenf
    I want to control my Marantz CD5400 with my CR80. I have tried all the Marantz codes listed in the CR80 manual (0029, 0157, 0180), but none of them seem to work.
    Any suggestions?
  8. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,565
    Edinburgh
    +1,265
    You coud do what I've just done, and purchased a Marantz RC9500 to control my entire system.
  9. radio
    radio
    Jun 1, 2005
    246
    Toronto, Canada
    +5
    I saw the harmony 880... i may get it its very sleek and sexy.
  10. LFCRules
    LFCRules
    Sep 3, 2004
    2,682
    +188
    I have the cheaper, and older Marantz 5200, but it is still superb. Everything in my signiture that has a remote control is controlled by it. Highly recommend these multi remotes, and the equivalent Philips pronto versions of the Marantz ones. They are expensive, but worth it in the long run :)
