CR80 remote codes
Discussion in 'Arcam Owners' Forum' started by seanb724, May 13, 2005.
  1. seanb724
    seanb724
    Is there a list of manufacture codes for the cr80 other than what came in the manual? I have a sony dvd/vcr combo that I can't get to work via the cr80. It runs everything else fine (sony tv, dish 942 hd-dvr, etc.)
    Thanks,
    SEan
  2. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,517
    Edinburgh
    +1,239
    Have you tried using the learning function to program in the commands you need from the original remote?
  3. seanb724
    seanb724
    I was going to hold off on doing that in case there was a code. I've used the learning function to get most of the DVR type buttons on the satellite receiver / dvr to work.
    /Sean
