CR80 Remote and Amstrad drx180 SKy+ box
Discussion in 'Arcam Owners' Forum' started by iranu, Jan 24, 2005.
  1. iranu
    iranu
    I have the CR80 remote and the Amstrad drx180 Sky+ box. I am trying to control the Sky box with the Arcam remote.
    Unfortunately I can't find the relevant remote control code anywhere. Manuals and net included! The learning/search function doesn't seem to pick it up either.
    I'm sure someone else must have this combo.
    Does anyone know the correct code for this? Is it even possible?
  2. Remboy
    Remboy
    I have managed to get mine done with learning function. If you follow instructions and place both remotes flat on table facing each other to perform learning, I found I had to lift the front of the Sky+ remote slightly angling it upwards to get the CR80 to receive the signal and learn. Hope that helps.
  3. iranu
    iranu
    Thanks very much. I should remember to :rtfm: more thoroughly. I wish they would make things a bit more intuitive.
  4. Roohster
    Roohster
    Jul 1, 2004
    2,555
    Derbyshire
    +1,280
    Ive tried everything to get my CR80 to learn SKy+ commands...and it just refuses.
