CR80 owners, please help
Discussion in 'Arcam Owners' Forum' started by NinjaKi11a, Aug 24, 2004.
Tags:
  1. NinjaKi11a
    NinjaKi11a
    Sep 7, 2003
    314
    16
    I have just bought a CR80 remote purely because it is most similar in lay out to a Sky+ remote. Strangely though, there is no preset code for it (why!?!) so I am trying to teach the CR80 the commands. Unfortunately, after about 10 commands (with no other components assigned yet) the double LED flash turns into a single flash and it doesn't get remembered. Please tell me a £60 remote has more than a ten button memory... Otherwise, what am I doing wrong? Cheers.
    GO ON KELLY!!!
  2. Roohster
    Roohster
    Jul 1, 2004
    3,787
    4
    2
    Derbyshire
    +3,791
    Ive never been able to get my CR80 to learn ANY sky commands :(
  3. NinjaKi11a
    NinjaKi11a
    Sep 7, 2003
    314
    16
    Well mine's on eBay now. According to Arcam support the CR80 won't learn Sky+ controls. I found that actually it did but they took up a horrendous amount of memory, to the extent that it would only store fifteen or so commands... which is useless.
    When the one thing that a hi-fi manufacturer can be sure of is that at least 50% or so of their customers are gonna have Sky+, can anyone explain to me the point of producing a remote which is not compatible with it!?
    *Grumble, grumble* ;)
  4. Roohster
    Roohster
    Jul 1, 2004
    3,787
    4
    2
    Derbyshire
    +3,791
    Is that 15 commands in addition to the "normal" pre programmed Arcam codes?
    I could live with that!
    How did you get it to learn ANY sky+ codes?
  5. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,566
    Edinburgh
    +1,266
    I've got mine to learn all the Sky codes I need. I learned Channel +, Channel -, Up, Down, Left, Right, TV guide, Info, Backup, Red, Yellow, Blue and Green.
  6. NinjaKi11a
    NinjaKi11a
    Sep 7, 2003
    314
    16
    Nowt special Rooster. Just programmed it the usual way.
    Seeing as I don't have full functionality, I'm not gonna keep it. There are so many remotes on the market, that I feel I'm not unreasonable expecting everything to work properly.
