CR80 learning help
Discussion in 'Hi-Fi Stereo Systems & Separates' started by dazz75, Apr 16, 2004.
Tags:
  1. dazz75
    dazz75
    I have the below system and am needing help in programming the Arcam CR-80 remote to the Pioneer DVD recorder.
    Arcam AVR200 Receiver(with CR-80 remote)
    Arcam DV88+ DVD player
    Pioneer DVR-310S DVD recorder
    Sony KP46WT510 TV
    Scientific Atlantic 3100HD cable box
    The codes for all of the other components are preprogrammed into the CR-80 but the Pioneer DVD-R is not listed in the manual as it is a relatively new product. I have tried learning function of the CR-80 but I can only get 1 button programmed, could the memory be full?
    Any help would be appreciated, thanks.
  2. ANDY_DUTTON
    ANDY_DUTTON
    Aug 27, 2002
    498
    28
    Cambridge
    +87
    The CR80 can learn about 20 keys so should have plenty of space left.
    Have you tryed using the codes from any of the pioner DVD players as it is likely that these will work most of the functions on the dvd recorder then you would only have to program the record specific buttons.
    Regards,
    Andrew
