CR 9000 Remote and Alpha 10 with DAVE
Discussion in 'Arcam Owners' Forum' started by angrex55, Dec 6, 2004.
  1. angrex55
    angrex55
    My Alpha 10 has no response whatsoever to the CR 9000 remote but I can control my DV 88, Hitachi TV and Scientific Atlanta box so the remote must work. At the suggestion of Arcam, I have set the system code on the Alpha to 16 but still nothing works. Any ideas?
  2. pinkmouse
    pinkmouse
    I found that unplugging my Arcam from the mains completely, and leaving it powered down for 15 minutes helped.
  3. angrex55
    angrex55
    Thanks. It turns out that the IR sensor was turned off! You can access these "service menus" by holding down "mode" and pressing "control" Rotating the volume control then scrolls through the menus.
  4. pinkmouse
    pinkmouse
    Yeh, It's just a shame my Alpha 10 is having a hissy fit, and won't recognise the Dave board. Time to find the schematic and get the hammer out! ;)
  5. steeled
    steeled
    Apr 23, 2002
    484
    28
    Maidenhead
    +53
    On rare occaisions mine would do that. Pull the mains lead out of the back and wait for 30 seconds. Plug back in and see how it goes.
    Hope that helps
  6. pinkmouse
    pinkmouse
    Nah, it's locked up completely, no display, remote or anything other than stereo mode. It's probably just a loose connector from the Dave module or similar, but I have to find the time to sort it out properly. Thanks for the thought though.
