CR-80 remote problem
Discussion in 'Arcam Owners' Forum' started by Gwisely, Jul 15, 2005.
Tags:
  1. Gwisely
    Gwisely
    My remote seems to have stopped learning functions, when following the instructions, I get to the bit where you press the button on the CR80 where you want the function to be stored and the LED flashes rapidly but when pressing the button on the original remote, the CR80 only flashes once rather than twice. Deleting previously learned functions doesn't seem to help. I've not had this problem before using the same original remote so I assume that the CR80s memmory is full or something - Any ideas?
  2. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,566
    Edinburgh
    +1,266
    It's probably full ,the memory of the CR-80 remote is very limited. I would recommend purchasing a dedicated learning remote such as the Marantz RC9500 which I have recently purchased.
  3. Gwisely
    Gwisely
    Is there anyway I can reset the remote to clear the memory if it's full?
  4. Gwisely
    Gwisely
    Aha - The memory was full, I've now deleted some old functions and the remote is accepting new ones.
