Quantcast
Question Cpu or motherboard
Uklegend
Can someone help me please i was cleaning my pc of dust and when i removed cpu fan cooler the cpu was connected but i never saw it and it dropped and bent pins they been straightened put back in socket went in clean when restart pc it does not boot the flashing for loading is not working at all I was told it was either cpu shock or my motherboard been shocked but the light on my b450 still turns on, which needs replacing cpu or motherboard ???
Yzeak Newton
It’s an idea to check your cpu, try to place your cpu in another motherboard, then you can see rather your cpu is damaged or not.
If you don’t have another motherboard ask your friends or relatives (keep some distance 😂).
If your cpu doent work your kan DIY it. Here is a link on how to do that
But first check your cpu and warranty!!!
good luck 😉!
