CPU Help
Discussion in 'Computer Components' started by gbailey141, Sep 20, 2007.
  1. gbailey141
    gbailey141
    Mar 2, 2006
    951
    46
    Southampton
    +183
    I have a Packard Bell MC1608 whch currently has a P4 3.06 processor 500 FSB.
    I am looking to replace it with a P4 3.6 800 FSB.
    Will I see a significant increase by doing this?
    I can buy the new chip for £52.
    Gav
  2. mjn
    mjn
    May 24, 2001
    24,295
    Herts, England
    +13,034
    I'd be checking to see if that Packard Bell motherboard can take CPU's with a 800 FSB first, and if it can whether the memory can run any faster.
  3. gbailey141
    gbailey141
    Mar 2, 2006
    951
    46
    Southampton
    +183
    Thanks for your reply. The motherboard can support upto 800mhz so no probs there.
    Gav
  4. VitalZign
    VitalZign
    Aug 21, 2007
    22
    3
    Nowhere, Oklahoma
    +7
    i honestly wouldnt bother with an upgrade like that....600mhz is not going to give you a significant increase in anything, even in modern gaming you are talking maybe a maximum of 10 frames per second, and maybe saving around 6-8 minutes per hour of video encoding....you would do much better by saving that money and puting it toward a new Pentium D dual core or Core 2 Duo system....
    upgrading processors like that are hardly ever sensible unless you are going from single to dual core or dual to quad core....
