CPU Heatsink Removal
Discussion in 'Computer Components' started by Hawklan, Sep 2, 2005.
  1. Hawklan
    Hawklan
    Oct 20, 2001
    6,343
    Essex
    +285
    Whats the safest and easiest way to remove a heatsink and the Thermal sealant from a AMD Althlon 64 3500 CPU
    The Heatsink is a Thermalright XP-120
    The reason why I want to do this is the CPU is running hotter than I'd like and reading up a bit more on the heatsink I might well have applied to much sealant
    Many thanks
    RON
  2. meansizzler
    meansizzler
    May 11, 2005
    7,574
    104
    London
    +265
    follow the instructions that came with the cpu/motherboard to install it and do it in reverse, or check the amd website...what sealent did you use, once all the brackes/screws are gone you have to twist the heatsink left and right slightly with some force to remove it from the cpu, well that's how it is for Intel Cpu's..
  3. dan1979
    dan1979
    Sep 16, 2004
    3,520
    83
    +201
    Not sure about a 64 but the Atholons you needed a flat head screwdriver to prise the clips off the motherboard (down and then out) then the heatsink and fan lifts straight off. If you got it on in the first place getting it off will be easy.
    Use tape head cleaner to remove the exising paste then re-apply with the edge of a credit card.
  4. Skunkpipe
    Skunkpipe
    The XP120 simply unclips.
    Once the clips have been removed gently easy teh heatsink off by twising from side to side.
    I use Arctic Silver cleaner and surface preperation to clean the surface of the CPU and heatsink. You can use meths or any alchohol based cleaner though. Arctic silver actually have some good instructions on their website for applying their compound
    http://www.arcticsilver.com/arctic_silver_instructions_big2.htm
  5. meansizzler
    meansizzler
    May 11, 2005
    7,574
    104
    London
    +265
    For removing the thermal paste get a bottle of Akasa Tim-Clean, from Maplin, at £6 a bottle it's expensive, but it does a good job and will last you a long time..
  6. Hawklan
    Hawklan
    Oct 20, 2001
    6,343
    Essex
    +285
    Thanks for coming back to me
    I used Arcric Silver paste - and looking at the link that Skunkpipe provided I put way to much on
    So it looks like this may be why I'm getting temps maybe 10 degrees higher than I should
    Many thanks
    RON
