CPU fan for older board
Discussion in 'Computer Components' started by GCDB, Dec 29, 2006.
  1. GCDB
    GCDB
    Sep 23, 2004
    321
    Wrexham
    My athlon 1100 cpu fan is making a noise and on the way out.Have cleaned it but to no avail. It was the original fan/heatsink with two clips ,socket a on a gigabyte ga71xe4 board.Originally a 700 duron cpu. Can i replace this with any newer fan/heatsink socket a? Have seen a quiet one in ebuyer for around 5.5 pound.Needs to be relatively quiet but dont want to spend much more than this.
    Gav
  2. m0rph
    m0rph
    Jul 2, 2004
    17
    Hi, you should be able to replace the fan with anything of the same socket, the only thing you will have to watch for really is any capacitors located close to the CPU and having a large heatsink, apart from this they should all be ok.
    What I would do is google the model number of the fan you are interested in on ebay and you should get the specs.
    Hope this helps.
  3. GCDB
    GCDB
    Sep 23, 2004
    321
    Wrexham
    Thanks, will try that.
    Gav
  4. Uridium
    Uridium
    Jan 29, 2005
    14,434
    North West Leicestershire
    +1,855
    Have a look at the user reviews on Ebuyer, usually give you a good idea of how quiet the fans are.
