Coverflow Duplicating Album Art
Discussion in 'Headphones, Earphones & Portable Music' started by MickEP, Jan 30, 2009.
  1. MickEP
    MickEP
    Dec 8, 2005
    499
    Blackpool
    +96
    I have recently applied cover art to my mp3 Albums using MP3Tag, but when I use itunes the cover art is repeated several time for different tracks (but not all the tracks on the album)
    Hope the above makes sense.
    I have attached a picture to hopefully make my explanation a bit clearer.
    Has anyone got any ideas why this is happening or what I have done wrong ?
    Thanks Mick
    [​IMG]
  2. adriandg
    adriandg
    Oct 27, 2005
    400
    You need to make it part of a compilation. To do this highlight all the tracks on that album, then right click and choose "get info". You then need to navigate to the tabs at the top which from memory I believe is organisation, if it's not it something like that. Then you will see a series of boxes about half way down is "part of a compilation" choose yes and then ok and sync your ipod. It should then appear as one entry in cover flow.
    Hope this helps
  3. MickEP
    MickEP
    Dec 8, 2005
    499
    Blackpool
    +96
    Thanks for the reply adriandg :smashin:
    I will give that a try when I get home tonight
    Thanks again
    Mick
  4. ChrisAV
    ChrisAV
    Dec 5, 2008
    766
    43
    Wirral
    +110
    Yes, do as adiandg, the tick box is on the 'info' tab, bottom right.
    Also, if you have albums with one main artist and one or more collaboratios (e.g. U2's with BB King - when love came to town), can't use this method as it changes the artist to 'Various' in cover flow. Instead select all tracks on the album, go to get info (as before), but this time go to the 'sorting' tab and in the right hand column put the name of the main artist you want displayed in the 'Sort Artist' box.
    Chris
  5. Palladio
    Palladio
    Sep 11, 2003
    1,208
    Essex, UK
    +143
    Great post Chris as I 've been changing Artists and Album artists to get round this very problem. Will now try the 'sorting' tab. :thumbsup:
  6. MickEP
    MickEP
    Dec 8, 2005
    499
    Blackpool
    +96
    Sorted!!
    Thanks for your help guys :thumbsup:
  7. Autopilot
    Autopilot
    Feb 5, 2005
    7,630
    Region 2
    +1,517
    As you are using the excellent MP3tag - in future set an extended tag to the album call ITUNESCOMP and set it to =1. Then itunes will also group them automatically when you add it to your library.
  8. rodney_nz
    rodney_nz
    Jun 3, 2004
    105
    +3
    Thanks for this thread, seems to have helped me out too but is there any reason why you need to do ITUNESCOMP? I added the field BAND and just set to BLANK and it seems to group them even if ITUNESCOMP is not set to 1
    cheers
  9. voodooflux
    voodooflux
    Nov 2, 2002
    267
    Redditch, UK
    +12
    It looks like the extended tag is called ITUNESCOMPILATION - at least that's the tag that the "Get Info" function of iTunes sets when the "compilation" flag is set to "yes". I just used MP3Tag to set this directly on the files and it worked.
    Very relieved to have found this thread - been tearing my hair out over this.
