couple of Widescreen questions...
Discussion in 'General TV Discussions Forum' started by JoeyL, Aug 9, 2004.
  1. JoeyL
    JoeyL
    Recently got a new Sony 32" widescreen, and after watching it now for a couple of weeks (and getting a green RGB screen eventually fixed), I got a couple of more queries...
    Am I right in believing the likes of Eastenders/corrie, lots of BBC/ITV programs on terrestrial are broadcast in 14:9 ratio?
    Well, when watching these programmes, I sometimes switch the TV to 14:9 mode, to remove the black bars from top & bottom. Is it normal for the TV to actually remove a little of the actual TV image as well as the black bars when I do this? I only noticed this lastnight when I used the up/down arrows on the remote and noticed that a little bit of the image was also hidden, along with the black bars. I assumed that only the black bars would get chopped. ? Is this perhaps a case of the broadcaster not transmitting a "perfect 14:9" ratio?
    Also, I noticed that while watching a 2.35:1 ratio DVD (with the thicker black bars on top and bottom), that the top black bar appears ever so slightly "thicker" on the left side than on the right. I think I corrected the problem by entering the TV menu and adjusting "Picture Rotation" a notch. Is it normal for these TV's to have slightly imperfect geometry?
    cheers,
    Joe.
  2. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,383
    Somewhere in South Yorkshire
    +5,770
    Yes via Analogue. This is the compromise they use for analogue transmissions where the original material is shot in 16x9. Via digital platforms, these programmes are full 16x9.
    Yes; it's called overscanning and pretty much all TVs do it. It's not in the broadcast - it's the TV.
    Yes, with CRTs. No, with LCD and Plasma.
  3. red16v
    red16v
    Aug 20, 2004
    552
    +5
    Joey. Joey, Joey - you've spent all this money on a wide screen telly and you're still watching TV via analogue transmissions ?. Go out and flash some cash and get a DTT box (assuming you're in the right area) and see it as it leaves the broadcaster. regards, yt.
