Couple of quick questions
Discussion in 'Microsoft Windows' started by dUnKle, May 28, 2005.
  1. dUnKle
    dUnKle
    Jan 1, 2001
    15,162
    +2,173
    Very new to this but will ask anyway
    (1) Can I use my HCPC with MCE as a film Jukebox ? I have 2 x 200GB Hds in there - is there a easy way of getting the DVDs onto the HD (in 1 for 1 quality) and then have them play via MCE
    (2) I have Sky+ sat 4 foot away from my HCPC - what would I need to buy to get that to be able to work on the PC ?
  2. Rambles
    Rambles
    Jul 14, 2004
    8,137
    UK
    +1,123
    Rip your DVD's using DVD Decrypter and install 'My Movies' it is an excellent app which makes MCE all the more wothwhile. here
    You can connect sky+ to your MCE via an MCE supported analogue tv tuner card such as the Hauppauge 150MCE and connect via a long s-video cable.
