Couple of quick questions for Targa DP-5100x Owners.
Discussion in 'Blu-ray & DVD Players & Recorders' started by ferris57, Oct 21, 2005.
  1. ferris57
    ferris57
    Jan 18, 2003
    874
    Can anyone with one of these tell me if it has 6 seperate analogue audio outputs at the back? in other words one for the Sub, front right, front left, center, rear right and rear left speakers?
    Also, I know it's meant to be an excellent divx player but what's your opinions on general picture quality when watching normal dvds?
    Lastly, any common problems with it?
    Thanks in advance folks :)
  2. craighome
    craighome
    Jun 21, 2005
    57
    Yes it has 5.1 audio out and so has all the outputs you have listed.
    Only had mine a few weeks and am more than happy with it so far.
    Had a slight problem with mine last night when it started puasing whilst playing a dvd and then a divx. Did a power down and then the problem was gone.
    I'm using the latest firmware as supplied by very kindly by NX3 from this forum.
    All in all very happy with it.
  3. ferris57
    ferris57
    Jan 18, 2003
    874
    Great stuff :) I just wanted to make sure it had 5.1 before ordering.
