Couple of questions regarding inputs
Discussion in 'Hi-Fi Stereo Systems & Separates' started by benjo09, Feb 5, 2009.
  1. benjo09
    benjo09
    Feb 5, 2009
    Farnborough/Derby (Uni)
    Im just browsing at the moment for either an amp or a system and what to connect up my xbox and ipod for now but in the future get a phono preamp and add a turntable and possibley a cd player.
    My first question is can any component be plugged into any free input on the rear even though its labelled? For example could I have my ipod plugged into the input marked CD?
    My second question is as long as I buy a phono stage for the turntable will it just plug into the AUX input?
    I'm sure I had another question but I can't think of it right now
    Ben
  2. oldnewbie
    oldnewbie
    Feb 13, 2006
    1,076
    63
    +164
    You can plug anything into a aux as long as you have the correct cable ie a turntable will just plug into a aux with just a phono cable and nothing else, the same goes for the ipod as long as you have a docking/charging station that has phono outs and a optical input for the 360.:thumbsup:
  3. thenicklouse
    thenicklouse
    Oct 5, 2007
    379
    +31
    Inputs are all the same Line Level. ( unless it is a dedicated Phono input with a built in Phono stage).
    the only problem you may have is remembering what you have connected to what.
  4. Mark.Yudkin
    Mark.Yudkin
    Sep 19, 2007
    10,043
    Zurich, CH
    +1,542
    Just to clarify with the turntable. If you use an external phono stage you can use any input except the phone input. If you do not use an external phono stage, you will need to use the phono input on the amp (so it must be present). You also need to match the type of the phono stage (whether internal or external) - MM or MC - with the cartridge type. Finally, don't forget that the turntable needs earthing to the amp.
    Your turntable dealer will be able to help you with all of this.
