Couple of HS2 questions?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Phil.LFC, Jan 6, 2004.
  1. Phil.LFC
    Phil.LFC
    Mar 31, 2002
    729
    Staffordshire
    +56
    Could someone please advise on the following?:
    When using Partial Erase to cut out rubbish at start of a recording I then have to FF to the end to partial erase the rubbish on the end - is there a quicker way of reaching the end of the recording to perform the erase?
    Also, is it better to always use FR mode when burning to DVD-R, whatever the length of the recording?
    Finally! - if I want to watch Sky+ whilst dubbing HDD>DVDR then can I connect Sky+ VCR scart to TV AV2 for this occasional viewing? I'm not going to be doing this very often but the option would be nice.
  2. applevenus
    applevenus
    Q1 I'm not sure
    Q2 I've been using XP mode for archiving DV tapes - I don't mind the extra couple of euro to archive important tapes. Not sure about FR - haven't really investigated it fully (yet)
    Q3 I've done this - it's "only" s-video but better than nothing - it's amazing how used you get to RGB quality....
    [edit - re-reading I realise you're talking about Sky+... I don't have that... yet.... in negotiations with she who must be obeyed]
  3. DaveP
    DaveP
    I thought that the VCR out was only composite, the same as other digiboxes. Are you sure it's s-video? Or, are you using the s-video output?
    Dave
  4. kenfowler3966
    kenfowler3966
    Jul 23, 2001
    844
    leeds UK
    +14
    Q1, there is no short cut.
    Q2 XP for anything under an hour FR for everything over.
    Q3 better than nothing, I get quite serious patterning via this input.
  5. jem
    jem
    Sep 24, 2002
    527
    +7
    You can do this but as you have Sky+ you have a better option. Buy an S-Video lead that has an S-Video socket with two phonos on one end going to a scart on the other - put this into AV2 (this is assuming that your AV2 socket will accept an S-Video signal - you may have to change the setting of AV2 to allow you)
    Or S-Video to S-Video along with the audio leads if your TV has that option.
    S-Video will give you a picture almost as good as RGB - on some sets it may even be better.
  6. Phil.LFC
    Phil.LFC
    Mar 31, 2002
    729
    Staffordshire
    +56
    :clap: Thanks for the answers:clap:
    I'll hunt around for an s-video lead - got one somewhere!
    I'm sure my TV has an s-video option on AV2 or AV3, but there is definitely an s-video socket on the side (out of sight) that is labelled AV4.
    Tell her it's brilliant, as it is, and SHE WILL love it too - my wife does! My 5 year old son even uses live pause now when he needs a wee-wee during Cartoons:rolleyes:
    Seriously, Sky+ is fantastic and if she's allowed you to part with so much cash for the HS2, Sky+ seems great value!
  7. Kevo
    Kevo
    Aug 23, 2001
    5,358
    Manchester
    +145
    The way I do it on my DMR E100 (may apply also to the HS2) is as follows....
    Use the Time slip function in normal playback mode to quickly go near the end of the recording.
    Add a marker.
    Go into Partial Erase mode and skip to the marker which will take you near the end.
    It would be a lot easier if you could use the Time Slip function whilst in Partial Erase mode which would make th ewhole process less long winded.
