couple of 435xde questions
Discussion in 'Plasma TVs Forum' started by Joe Pineapples, Jan 23, 2005.
  1. Joe Pineapples
    Joe Pineapples
    Oct 23, 2001
    7,375
    Doncaster
    +1,147
    Just helped my brother set up his pioneer 435xde, and pretty much got everything sorted. A couple of things have cropped up though, if any other xde owners can help us with.
    1 The vcr is connected to input 2 (scart) on the media box, and the other scart from the vcr to the sky digibox. we can record off sky no problem, by selecting 'L2' on the vcr (corrosponding to its rear scart connection), but not sure how to record off the digital tuner in the media box. Flicked hrough all the av inputs/outputs on the vcr, but nothing comes through. A thought has occured while i'm typing this, that only one of the vcr scart sockets is niput/output and the other is just output - as a video tape plays through the meida box no problem.
    2. Is there a button on the remote to remove the dreaded red dot, when watching through the digital tuner?.
    cheers
    joe
  2. jwramsay
    jwramsay
    Sep 7, 2004
    1,629
    West of Scotland
    +72
    Surely the RED DOT means No channel?!
  3. dave0523
    dave0523
    Dec 28, 2004
    261
    Somerset
    Red dot on Sky? In the corner of the screen? Annoying innt? Hit "Backup" and it goes, until the next ad-break! :zonked:
  4. Joe Pineapples
    Joe Pineapples
    Oct 23, 2001
    7,375
    Doncaster
    +1,147
    red dot on sky is not the problem - like you say, just press backup. Its when viewing terrestrial programmes through the digital tuner, you get similar on-screen garbage like 'press start' (in red) etc - need to be able to turn this off.
  5. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    My freeview box has an 'exit' button that does this, I thought there was a similar on the XDE remote? VCR wise, there is a little black sliding switch on the back of the media box to enable 2 way audio/video on scart 2. Your VCR scarts, one is labelled decoder, and is in only, the other, labelled TV, is bi directional. This is probably L1. By selecting L1 for recording you should now bw able to record freeview.
  6. Joe Pineapples
    Joe Pineapples
    Oct 23, 2001
    7,375
    Doncaster
    +1,147
    thanks MAW, i'll give those suggestions a go.
