handsy
Hi, just received my new M87 (P7, so July build). Coupla immediate questions :
1. When I chose JustScan on HDMI input, BBC HD on my V+ box started jerking a bit, as soon as I swapped back to 16:9 it went away....why ?
2. On my old Sammy I'd set it up as 4:3 for my HDMI connection to V+. That way it would automatically switch between the 2 depending on what channel was on. i.e. it would be 4:3 most of the time on UK Gold, if I switched to BBC1 it would automatically switch to 16:9. This M87 does not appear to do that, which is annoying.
I'm hoping I'm doing something wrong ? I have yet to check the firmware version, or plug in and test freeview.
Help welcomed
EDIT: just checked f/w - I have 2000
Help welcomed
