Country versions?
Discussion in 'Blu-ray & DVD Players & Recorders' started by dvdkid, Jan 16, 2005.
  1. dvdkid
    dvdkid
    Hi all
    :lease:
    I was hoping someone could help me answer this question. I live in sweden but travel alot in the UK and Germany and i have noticed that home cinema equipment seem to be about 20% cheaper in Germany and about 15% cheaper in the UK. The question then is ofcourse if i could by a DVD recorder in Germany and install it in sweden, does any1 know if there are country versions on the DVD recorders, especially panny e95 and sony 1000
    any answer appreciated. :thumbsup:
    Tnx
    /dvdkid
  2. kenfowler3966
    kenfowler3966
    Jul 23, 2001
    844
    leeds UK
    +14
    Different countries use different tv broadcast standards, hence the tv tuner for germany will not work in the uk and vice versa. Probably different again in sweden too. The recorder will still work though and will record if you can feed from another source such as a cable or sat box, and the supply voltage is correct.
