Counter-Strike: Movement is in Slow-Mo.
Discussion in 'PC Gaming & Rigs' started by real, Jul 20, 2004.
  1. real
    real
    Oct 31, 2003
    4
    London
    When I play cs 1.5 the player seems to move in slow-motion. One minute it is fine and the next I can hardly move. The gun im using at the time also goes into slow-motion mode. How can I fix this problem?
    cheers
    real
  2. Adrenochrome
    Adrenochrome
    Dec 20, 2002
    8,761
    Babel Sensurround
    +207
    Sounds like a ping issue to me.
    But i am not the brightest star in the sky when it comes to this kind of stuff.
    Adrenochrome.
  3. real
    real
    Oct 31, 2003
    4
    London
    Nah my ping is fine. A near constant 20 on most servers.
  4. real
    real
    Oct 31, 2003
    4
    London
    Any more ideas?
  5. Hawklord
    Hawklord
    Feb 15, 2003
    3,441
    Aldershot, Hampshire
    +265
    We really need to know more about your system. What cpu, motherboard, memory and graphics card you are using and the relivent drivers and directx version you are currently using. Is the game patched up to the latest release?
    There are lots of things that could cause the issue you describe you just have to narrow it down till you find the culprit and sort it :smashin:
  6. Sinzer
    Sinzer
    May 25, 2002
    5,793
    +1,108
    Definately sounds like a connection issue, ping might be fine but your choke or packet loss might be high.
    Other than that it may be mouse, you could try using the mouse in a serial port if you are using it on USB or vice versa.
