Countdown Intro - Video Editing!!!
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by WBC, Jan 19, 2005.
  1. WBC
    WBC
    Guys,
    Anyone have a link to some countdown intros for the beginning of a video I'm editing?????
    All links welcome!!
    Stace :D
  2. Brian110507
    Brian110507
    Don't know of any links but I've got 3 or 4 I could send you if you PM me your e-mail address.
  3. vonhosen
    vonhosen
    Jan 6, 2003
    1,907
    41
    London
    +14
    I've got one (countdown from 10) I can send to you if you want.
  4. WBC
    WBC
    Guys,
    I've pm'd you both.
    Very Much Appreciated
    Thanks!!!
    If I can ever return the favour, I'll do my best!!
    Stace :D :clap:
  5. toong
    toong
    can u sent to me to? thanks before guys....
  6. toong
    toong
  7. vonhosen
    vonhosen
    Jan 6, 2003
    1,907
    41
    London
    +14
    :confused:
    I haven't got any PM , but if you've got what you need already :smashin:
  8. vonhosen
    vonhosen
    Jan 6, 2003
    1,907
    41
    London
    +14
    I see from your other post you are using Vegas. To save me sending you a fairly large file, I checked the website I told you about ( www.vasst.com ) & you can get a .veg file for a countdown intro there.
  9. WBC
    WBC
    Guys,
    What software would I use to make my own?????
    Any suggestions?
    Stace
  10. Brian110507
    Brian110507
    Any video editing software - do you have Microsoft MovieMaker on your PC - that will do it. One of the ones I sent you I made using Ulead VideoStudio 8 -did they work for you ?? - what editing programme do you have ??
  11. WBC
    WBC
    They all worked cool thanks!!!! Which one was yours????
    Been using an old copy of version 7. Do you just create slides with transitions or is there something more complex at foot????
    Stace :D
  12. Brian110507
    Brian110507
    Mine was the one with just numbers and a background which changed from orange to red as the numbers counted down.
    Do you mean Ulead VideoStudio Version 7 if yes then to create your own countdowns simply create a series of 'Titles' with numbers or whatever on them and put them in the title track and set the duration of each one for one second. Then put whatever sort of background you want in the top two video tracks - can be still images - can be videos - can be colour blocks - can have transitions and fades etc. your choice.
    Then go to 'Share' and choose "Create Video File" and select "Custom" to choose to make an .avi file. Save this file and there you are - ready for future use.
  13. Brian110507
    Brian110507
    Toong
    My e-mails are being returned to me with the message that your inbox is full - if you want me to send more please empty your inbox and let me know.
  14. klr10
    klr10
    Dec 20, 2003
    801
    28
    Sawbridgeworth
    +27
    Adobe Premiere has a built in professional countdown option similar to the one used in film production.
  15. toong
    toong
    thanks man, i got what u'r send to me.
    i already activate again that email, i got long not used it..
    can u send more for me. that film that u'r send to me do not got a sound. can u send to me which got sound effect....
    hi everyone i used vegas video for editing wedding clip...does anyone have the same as i do.maybe we can share some experience...
  16. Brian110507
    Brian110507
    They are only countdown timers and don't normally have sound although one of the ones I sent you called "open-count" should beep as the numbers change. You can add any sound effects you like to them in Vegas when you use them. I'll send you a couple more - but no sound ones I'm afraid.
  17. Gromit
    Gromit
    Nov 30, 2004
    524
    Copenhagen
    +42
    To Vonhosen & Beejaycee,
    You´ve got a PM.
    All the best,
    Gromit
  18. vonhosen
    vonhosen
    Jan 6, 2003
    1,907
    41
    London
    +14
    Gromit
    I've sent you one .avi & one .mpg
    VH
  19. Gromit
    Gromit
    Nov 30, 2004
    524
    Copenhagen
    +42
    Thank you very much. :smashin: I appreciate that.
    Regards,
    Gromit
  20. Gromit
    Gromit
    Nov 30, 2004
    524
    Copenhagen
    +42
    Beejaycee,
    Thank you so much. :smashin:
    I really like the oldfashion one.
  21. Gliese 581c
    Gliese 581c
    Feb 3, 2002
    8,768
    On AVForums
    +570
    could you guys PM to me too please ?
  22. Brian110507
    Brian110507
    Not sure who you want to PM you aRCaM, if you want the countdown videos you need to PM vanhosen and myself with your e-mail address, or do you have some count downs and want Stace, Gromit an Toong to send you their e-mail address so you can send the countdowns to them
  23. Gliese 581c
    Gliese 581c
    Feb 3, 2002
    8,768
    On AVForums
    +570
    thx beejaycee, VH helped me out :)
  24. ethridged
    ethridged
    Sep 25, 2009
    How and where is this count down clip in Premiere pro?
    Cant seem to find it.:thumbsup:
