Question Could you critique my surround setup
Discussion in 'Home Cinema Building DIY' started by mark00754, May 6, 2018.
  1. mark00754
    mark00754
    May 6, 2018
    uk
    Hi could someone critique my setup, ive just plastered my living room so ive not set any of this up yet
    the setup ive got is
    Denon AVR-X2400H 7.2 Channel
    Q Acoustics Q3000 Cinema Pack 5.1 System
    2 of Polk Audio V60 High Performance Vanishing In-Ceiling Speaker
    SAMSUNG QE75Q7FAM 75" Smart 4K Ultra HD HDR QLED TV
    3100 PQI
    my prev setup was a 9.1 soudbar with 2 x 360 speakers so this is my first DIY setup, so looking for any advice on what ive purchased before i set it up
    i think i should of got a better avr?
    thanks in advance
  2. wl1
    wl1
    Sep 10, 2007
    2,251
    116
    +884
    I think that looks a perfect, well matched setup. The AVR will have everything you need, and won’t let you down.
    Make sure you take the time set up the Audyssey XT correctly, there are lots of guides so you don’t make some common mistakes. I.e. Set up for ALL Mic. Positions with up to 60cm from the MLP. And set your Crossovers to 80Hz as a minimum, but never lower than what Audyssey recommends and the Denon sets.
    You have the option of buying the Audyssey App if you want to fully tune to your preferences.
    You have not said what sources are feeding this, but a BR player for HD sound, making sure you always check the Sound formats are correctly selected and if Atmos is available, that you select that Sound mode. Use the Display to check for correct Inputs and Outputs.
    Best of luck, enjoy it. Don’t have buyers remorse before you even start
  3. mark00754
    mark00754
    May 6, 2018
    uk
    thanks for your reply wl1
    im just researching the Audyssey XT as i didn't now about that
    My main source will be from my QNAP TS-453A this is where il stream all my movies ect
    other sources are ps4 and Sky Q
  4. wl1
    wl1
    Sep 10, 2007
    2,251
    116
    +884
    Those sources will be fine and fit in with your system.
    http://www.willowville.net/ht/Audyssey Setup Guide.pdf was the guide I was referring to....
