Could someone tell me the difference between these?
Discussion in 'Home Cinema Speakers' started by Maxheadroom, Aug 10, 2005.
  1. Maxheadroom
    Maxheadroom
    Aug 3, 2005
    40
    Monitor Audio Bronze B4
    Monitor Audio Bronze B6
    The B4's have a skip load of awards but I can't even find a review of the B6's and there's only about £50 between them in price.
    It'll mainly be used for a home cinema set up (not so much music).
  2. Menelaos
    Menelaos
  3. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    +25
    In theory I would prefer the B4 to the B6... and also the B2 to the B4... as with any other bookshelf vs Standmount (exception to very expensive and very good built ones).
    That saves money to buy a better sub, since you need one!
  4. Beobloke
    Beobloke
    Aug 10, 2004
    1,312
    Out in the Sticks!
    +65
    Well, obviously the B6 is '2' better than the B4. :rotfl:
    Sorry - i'm ramping up for one of those silly Friday afternoons................ :D
  5. Sniper
    Sniper
    Apr 27, 2004
    1,294
    +80
    The difference is in the fact that low end freqs are divided into 2 drivers giving better output and very marginal improvment in freq range.
    You'll need a slighly better amp to driver them properly.
    If you have to get floorstanders and you're getting a sub go for the B4, if you're not getting a sub get the B6. If you don't mind bookshelf spkrs get the B2 (as Falp said) and use the money on a better sub.
  6. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    +25
    And get better dinamics, atack, control and less ressonance.
    Instead of a boom boom sub, get a REL or MJ acoustics.
