Could someone pse tell me the benefits of a scaler and a bargin priced one.
Discussion in 'Projectors, Screens & Video Processors' started by mistycat, Mar 20, 2005.
  1. mistycat
    mistycat
    I have purchased a Samsung 50 inch DLP. I was wondering if a scaler will give me a pq almost that of HDTV. Also, I was wondering if there was one for a bargin price. I am not after perfection, just as close to HD from my sky+ box that I can get.
    Any help would be greatly appreciated. :hiya:
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    What resolution is the Samsung? Scalers can give excellent PQ, whether you'd compare it to hidef is perhaps open to debate.
  3. mistycat
    mistycat
    1280 by 720p. It is the L50HX model. Cheers
  4. Mike Khain
    Mike Khain
    Hello,
    I would probably recommend you DVDO iScan HD or HD+ depends on the setup. The picture quality out of your dvd would look very simular to HDTV broadcast. We actually used to have Samsung DLP in our office and unfortunately i would say that we have not seen a scaler which would be able enchance the picture quality from the sat by much.
    Thnak you
    Best regards,
    Mike
  5. dilsher
    dilsher
    The Lumagen HD is the other one to check out at the price point...
  6. Thunder
    Thunder
    Feb 26, 2004
    1,763
    41
    +14
    From what Ive heard you cant bypass the samsungs internal scaling, so Im affraid no scaler will have any worthwhile effect :(
  7. Gordon @ Convergent AV
    Jul 13, 2000
    13,999
    +2,803
    Actually a scaler can still have a verybeneficial affect even if there is still rescaling being done by the display.
    Remember a scaler has to take in analogue and dgital sources, de-interlace them where possible and then scale them. In amongst this analogue signals have to be digitised, all signals likely as not go through colour space transformations. Noise removal processes may happen and in the case of Lumagens you also have ability to do 5 point rgb gamma calibrations on each input and memory...where there may not even be an option to do it in the plasma. Then there's Y/C delay ablities to line up colour and black and white info on screen to remove fringing....and advanced colour decoder adjustments to deal with sources with non spec signals....so all in all quite alot of areas where a scaler could prove worthwhile...
    Gordon
  8. dilsher
    dilsher
    Hey gang
    Been looking on the Plasma Enhancer Pixel Plus thingy website - any one know about this newbie???
    Dil
  9. Eitzel
    Eitzel
    Nov 3, 2004
    654
    46
    Top Secret-Anyone coming anywhere near my Pioneer
    +143
    My Lumagen Vision DVI (calibrated by Gordon BTW), makes a MASSIVE difference to Sky. And everything else, come to think of it. Well worth the money. :clap:
  10. Thunder
    Thunder
    Feb 26, 2004
    1,763
    41
    +14
    Hi Gordon, it was just that I remembered that John had tried external scaling (the Lumagen I now own in fact :) ) with his Samsung and had no success :smashin:
