Question Could someone help me decide between 2 TV's please
Discussion in 'What Is The Best TV For You?' started by Andyt83, Dec 15, 2017.
Tags:
  1. Andyt83
    Andyt83
    Dec 14, 2017
    17
    Bristol
  2. EndlessWaves
    EndlessWaves
    Apr 7, 2008
    13,900
    Norfolk
    +2,535
    Well I could tell you what would work best for me but that's probably not of much help to you.
    If you want the best option for you then you'll need to give us some information on how you use the TV, what you watch, what you're expecting from the TV and so on.
  3. Andyt83
    Andyt83
    Dec 14, 2017
    17
    Bristol
    Sorry well just picked up a ps4 pro so primarily for that also watch netflix via the ps4 pro fairly small living room sit about 7 feet away from TV usually facing it directly head on.
    Just looking to get the best picture possible in my price range
  4. Dodgexander
    Dodgexander
    May 29, 2007
    15,020
    +4,360
    If you are facing the TV directly on the panel type on those two TVs isn't ideal, you could instead opt for different models with a VA type panel which will give you better overall picture quality.
    Models like the Sony 55XE70xx series or Hisense 55N6800.
  5. Andyt83
    Andyt83
    Dec 14, 2017
    17
    Bristol
    Thanks, would this one be better:
    SONY BRAVIA KD55XE7073 55" Smart 4K Ultra HD HDR LED TV
  6. Dodgexander
    Dodgexander
    May 29, 2007
    15,020
    +4,360
    Yes that is one of the Sony XE70xx series TVs I mentioned. The differences in the xx in the model number only relate to colour/motionflow strength and aren't important, so whichever you can find cheaper.
    You can see the full line up on Sony's website. Sony XE70 | LED | 4K Ultra HD | High Dynamic Range (HDR) | Smart TV
    If you can help it i personally would buy elsewhere, I am not a fan of Currys aftersales and customer service.
  7. Andyt83
    Andyt83
    Dec 14, 2017
    17
    Bristol
    It’s a little bit of a weird situation basically work give us £800 a year that can only be spent in Curry’s and has to be spent on tech stuff so was planning on picking up a TV and sound bar otherwise I agree I don’t like Currys
