Could somebody measure a PW6 for me, please (including bezel)
Discussion in 'Plasma TVs' started by TheChump, Nov 13, 2004.
  1. TheChump
    TheChump
    Looking at buying a PW6 in the next couple of weeks.
    Took a look at the LG RZ-42PX11 this morning just to satisfy my curiosity - very impressed for the price. Picture quality good and the amount and quality of connections were fantastic. However, when I measured the full width of the TV including non-removable speakers either side it came to 120cm wide :eek: :eek: Now I have a full IKEA Bonde cabinet with shelves and cabinets etc. that's only 107cm wide and the LG is just not going to fit :thumbsdow :thumbsdow :censored: :censored:
    It got me thinking whether any 42" plasma is going to fit in this size cabinet - working out the screen size means a 16:9 42" plasma should only be around a 37" (94cm) visible picture plus whatever the bezel width is as well. Could someone please measure a PW6 for me including the bezels as well, just in case (otherwise it's off to projector land for me!)
  2. loonatic
    loonatic
    Jan 4, 2003
    1,877
    41
    Springwell Village, Gateshead
    +16
    Well according to the spec sheet it's 40.2" wide and 20.4" tall.
    Cheers, Lee
  3. TheChump
    TheChump
    Thanks very much! :thumbsup: :thumbsup:
    Looking good for a PW6, then.
  4. r1chuk
    r1chuk
    Jun 10, 2004
    i think I have the same Ikea unit as you do, can you advise if you found a 42" plasma screen that fits inside the hutch??
    Cheers in advance
