Could my router be the main source of the problem
Discussion in 'Playstation Forums' started by Darsh, May 2, 2007.
  1. Darsh
    Darsh
    Feb 23, 2007
    662
    London
    +26
    Hi guys my problem is that i can't seem to sign into the PSN during the peak time hours i get on during the night though. My signla strength is always at 100%. Today i rang Sony for help they said i need to have the UDP/TCP ports open and also ask my router company to enable DMZ so after that was all done it should hopefully work. Well yes and no i was able to connect but then i got signed out again.
    I have heard my router which is a NETGEAR DG834PN is not compatible with PS3 just yet and Sony will be giving a update soon for it.
    Also on the NETGEAR Smartwizard under firewall settings i was given all the outbound services and in the inbound services i have DMZ only in there. Do i need anything else in this section? If i do please let me know
    Darsh
  2. Darsh
    Darsh
    Feb 23, 2007
    662
    London
    +26
    Just solved my problem all i done was change from a wireless connection to a wired connection and now i can sign into the Playstation Network with no problems :D just wish their wasn't these errors with wireless connections.
  3. Tony Hoyle
    Tony Hoyle
    Aug 4, 2005
    3,347
    103
    Stockport
    +231
    Wireless is fairly unreleliable - it clashes with video senders, wireless phones, even bluetooth, and picks up interference from things like microwaves. Generally if something is not going to move around use a wired connection - especially for gaming that requires a good solid connection (if you can't get a cable there use homeplugs).
  4. fdxd
    fdxd
    I had issue swith my old b wireless router . Upgrading to G really helped me. ALso you have the option of using electrical sockets.
