quattro
Established Member
I've had my system set up now for a few weeks and I'm curious to know whether any inprovments could be made for no extra cost or slight cost, thne main issue is regarding the Xbox connects as i would like a better PQ if possible.
Connections as they are now are
Jamo DVD conected to PW6 Via Vandamme conponent lead to conponent board on PW6.
Sky+ conected via Scrat to JS RGB/VGA converter via Vandamme vga cable to PW6.
Xbox conected to Quintro Via Xbox standard cable then via Techlink scart cable to scart board on the PW6.
Would i be better conecting both the Sky+ and Xbox to the Quintro and then connecting this to the JS rgb/vga converter then vga to the PW6? would i loose any pic quality do this? also is it wise to upgrade the xbox cable?
Cheers in advance
Quattro
Cheers in advance
Quattro
