Docta teef
Established Member
I ve been using a book case for my projector (an H56) for a couple of weeks but at the weekend i ordered an LMP universal mount. Ive mounted the main part of the bracket no prob but when it came to the face plate i noticed that the screws to connect to the projector where rather long. As a result i used the 12.5mm spacers plus washers. Even so the screws needed to go a very long way into the pj. When i came to test the pj it started up fine but could not find any signal from the component(vGA) input. Ive tried every other input source but not signal. I know that the component lead is ok as ive connected an lcd tv and that works fine. Is it possible that these long screws could have damages one of the circuit boards inside. Is so what the hell do i do and any idea what its gonna cost.
