Could be a silly question!!
Discussion in 'Home Cinema Speakers' started by c123, Oct 20, 2005.
  1. c123
    c123
    Oct 2, 2005
    44
    Have recently bought myself some Mission V61's to go with my NAD320BEE amp. This is my first separates unit and obviously you want everything to be perfect :) .
    When i was putting the speakers in to place i accidentally pushed the tweeter in a little :( . it has left no mark or indentation. Now this could be a stupid question but is it possible i could have done any damage, is there anything immediately behind the tweeter to damage? Everything sounds fine, but i'm just hoping i haven't caused any problems.
    I suppose i'm just a little paranoid, but could there be any damage?
    C123.
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,618
    Rainham Essex
    +2,547
    If there is no visible damage then the only way to check if it is still OK is to listen to it and compare it to the other speaker. TBH though the speakers are designed to move and therefore with nothing visibly damaged I would doubt that there is anything to worry about.
    Mark.
  3. micb3rd
    micb3rd
    Dec 8, 2001
    1,047
    48
    Bedfordshire
    +67
    As long as it is not dented it will be fine. I very much doubt is damaged.
    Mabye if you had grease or slime on your finger and coated the tweeter cone then you could have an issue but other wise you are ok.
  4. OriginalArnie
    OriginalArnie
    A friend (the clumsy oaf :cool: ) did the exact same thing to one of my Mission 750 Special Edition speakers when I first got them, four or five years ago; I can't say that I've ever noticed that speaker performing any worse than the other one!
  5. chedmaster
    chedmaster
    Jan 29, 2005
    2,661
    68
    +28
    it would probably of sounded perfect even if it had dented
