Cost of DVD-RAM's
Discussion in 'Blu-ray & DVD Players & Recorders' started by joels, Nov 26, 2003.
  1. joels
    joels
    Hello,
    I am thinking of going with the DVD-RAM format when I buy my DVDR. The cost of DVD-RAM's does put me off a little though. Does anyone know of a place that sells cheap DVD-RAM's? £5 for a DVD-RAM compared to £2 for a DVD+RW is a big difference!
    I live in the UK and I was wondering if I ordered some discs from the US, for example http://www.meritline.com/4ridvdire.html, would they work on my UK recorder?
    Are Ritek DVD-RAM's reliable? Could they be used with a E50?
    Thanks in advance,
    Joel.
  2. malcom
    malcom
    Aug 25, 2001
    526
    +4
    SVP are selling double sided RAM discs in a caddy for £5-89. Works out less than £3 per 4.7 GB. I personally have not tried the above brand yet. As i have plenty of caddyless mirror brand RAM discs that were just £3-00 each but are out of stock at SVP at the moment.
    I didn't know Ritek did RAM discs! I have trouble with there DVD-R on my Panny machines but RAM is RAM so I expect they would be ok. Where have you seen Ritek RAM discs advertised??
    Remember when comparing the cost of RAM to that of +RW that RAM discs have a life expectancy of some 100,000 writes where as +RW is only a thousand and also the RAM discs in a caddy are protected from sticky fingers and damage. well worth any extra cost me thinks.
    Go for it joels the RAM/DVD-R format is just the tops.
    http://www.blankdiscshop.co.uk/acatalog/catalogbody.html
  3. joels
    joels
    Well you may of just swayed me to go for DVD-RAM :)
    I found the Ritek RAM discs at www.meritline.com but the shipping costs from the US seem very large :(
    Do the DVD-RAM machines like the E50 take both caddy and non-caddy discs?
    You wouldn't happen to know if and when SVP will get some more mirror brand discs in? Is there anywhere else that sells them?
    Thanks again,
    Joel.
  4. happyhooker
    happyhooker
    Nov 26, 2003
    24
  5. panaman
    panaman
    Nov 17, 2003
    295
    Hampshire UK
    +14
    I only buy single sided 4.7GB Panasonic DVD-RAM in caddies and pay £6.99 with free shipping. From here ....
    DVD-RAM
    I can't really see the point of buying the double sided as they are virtually the same price as 2 x 4.7GB. I suppose they take up less room. If the recorder could record/play both side without having to turn it over, then I could see the point :cool:
    I have found their service to be excellent and come recorded delivery in a couple of days.
    I would rather pay more and have official Panasonic disks, people will probably think I'm mad, but that what I like :rolleyes:
    BTW with Panasonic and RAM format you get the wonderful Timeslip feature which is amazing, plus you can record and watch a program form the same disk at the same time :smashin:
  6. ShaunIOW
    ShaunIOW
    7dayshop do a 5 pack of Panasonic non-caddied 4.7Gb DVD-RAM discs for £14.29 + 99p delivery - works out at £3.06 each.
    I use a mix of both caddied and non-caddied - caddied for watch and wipe programs, non-caddied for what I want to keep, as it is easier to transfer to my PC and burn to DVD-R (my PC DVD burner only takes non-caddied RAM discs).
  7. dude1971
    dude1971
    Yes, the e50 takes caddied and non-caddied RAM.
    I think the difference is price between RAM and DVD-RW is justified by the flexibility of DVD-RAM.
    Regards
    Dude
  8. Gary D
    Gary D
    Jan 9, 2002
    7,770
    +826
    i'll second what dude says above, the flexabilty of RAM is fantastic - the timeslip function is a god send.
    Gary
  9. joels
    joels
    Thanks guys for all your suggestions and help! I've ordered my E50 and I'm going to get my disks from 7dayshop. :) I'm glad that I asked for your advice and went for RAM instead of going straight for RW. Can't wait for the boxes to arrive! ;)
    Thanks again,
    Joel.
  10. sparkybun
    sparkybun
    Jan 6, 2002
    1,185
    41
    EN8 area
    +23
    hi,
    Caddied RAM - http://www.lynxdv.com/index.php? area=product&name=ram&type=9
    Good value. NOTE: Double sided (9.4GB) therefore cheaper than from 7dayshop!!
    cheers
    Mel
  11. pentode
    pentode
    Dec 17, 2002
    109
    West London, UK
    +4
    I've just phoned 7dayshop & they're out-of-stock of the Panasonic 4.7GB DVD-RAM 5-packs (advertised @ £14.29), with no delivery date for new stock.
  12. malcom
    malcom
    Aug 25, 2001
    526
    +4
    The mirror discs have been out of stock for at least a couple of months. SVP are excellent people to buy from but when they lose stock of something it does tend to be quite a while if and when they return.
    I have got lot's of the single sided Mirror diasc and have had no problems at all with their reliability. If you see advertised double sided RAM discs I would advise you to give them a miss because if you get finger prints on the recording surface the machine is unlikely to read them until wiped clean.
    Now it's quite easy to avoid getting fingerprints on the single sided discs but almost impossible with the double sided. that is why I advise you avoid them.
    As for caddied double sided RAM disc I think they are a great way of saving space and turning them over is no different to putting in a new disc.
    Good luck with your new machine I am sure you will be right well pleased with the quality you get.......
  13. CH3
    CH3
    Jun 27, 2002
    169
    +7
    as above.. www.lynxdv.com £5.95 for a 9.4GB double sided, cadied DVD-RAM. Been using them on my Panasonic HS2. U don't even have to format them.
  14. SmokyToby
    SmokyToby
    Nov 26, 2003
    35
    Ipswich, Suffolk
    I got Panasonic 9.4GB double sided, caddied DVD-RAM for £9 and single sided 4.7GB caddied for £5 from www.avland.co.uk
    Orders over £20 are post free. But check out availability, as I had to wait 3 weeks for mine.
  15. patmyhead
    patmyhead
    Feb 11, 2002
    588
    I o M
    How does the caddy disks go in the HS2
    P@T
  16. sparkybun
    sparkybun
    Jan 6, 2002
    1,185
    41
    EN8 area
    +23
    hi,
    They accept caddied disks
    cheers
  17. jem
    jem
    Sep 24, 2002
    527
    +7
    It just goes into the tray with the metal section leading like a floppy disc on a PC. If it's a double sided version, put the side you want to use face up.
    You'll see that the non-caddied versions sit down into the tray a bit.
