Cost for Plasma on Wall
Discussion in 'Home Cinema Building DIY' started by themmings, Dec 13, 2002.
  1. themmings
    themmings
    Nov 21, 2002
    382
    Northampton
    +4
    Has anybody had first hand experience of how much builders tend to charge [£] to prepare a plasterboard wall for hanging a plasma to its wall mount bracket.
    I ain't gonna be responsible for pulling half my living room wall down and smashing my new £5+k toy all over the floor.
    I can't even spell DYI - let alone do it :D
    Tim
  2. installer09
    installer09
    Aug 26, 2002
    415
    16
    SWINDON ,WILTS
    Depends on how much work it involves , I usually give an estimate first. The last one I did was about £500 , that included hiding the cables.
  3. themmings
    themmings
    Nov 21, 2002
    382
    Northampton
    +4
    Thanks installer09:
    Can you give me an idea of what you had to do to the plasterboard wall to prepare it for hanging?
    Tim :D
  4. installer09
    installer09
    Aug 26, 2002
    415
    16
    SWINDON ,WILTS
    Depends on how the wall is constructed , is it dry lined or a timber framed wall? the last one I did was dry lined so I used long fixings that went through into the main wall , then I ran all the cables down the cavity. If it is timber framed and you are very lucky the uprights may be in a good position to fix to, if not I cut out a section of plaster board and fit cross members between the uprights in the desired position.
  5. themmings
    themmings
    Nov 21, 2002
    382
    Northampton
    +4
    Installer09:
    Not too sure.
    It is an outside wall - seems like plasterboard and if you tap it you can definately hear a difference when you pass over some kind of beams.
    Tim
    :confused:
  6. installer09
    installer09
    Aug 26, 2002
    415
    16
    SWINDON ,WILTS
    If its an outside wall it will be drylined , usually plasterboard is just stuck on to the wall with blobs of plaster , these are what you can here when you tap on the wall and your not getting a hollow sound , maybe . Difficult to say exactly though with out inspecting it.
  7. boltoa
    boltoa
    Oct 10, 2002
    920
    2
    46
    Nottingham
    +104
    There was a whole thread about this somewhere. I used one of the suggestions for my drylined wall. Got a length of 14mm dowell, cut 8 of 10cm lengths of it. Drilled just over 10cm into wall, filled hole with "no more nails". Hammered dowell in. Left to dry, then screwed wall mount into these. Once it was all set, I managed to pull up my entire 115kg (!!!) weight off it with no problems, so had no qualms about 35kg of plasma :).
    Andrew
