Corsair force 3 ssd
Discussion in 'Computer Components' started by ArcAngel78, Jan 6, 2012.
  1. ArcAngel78
    ArcAngel78
    Jul 18, 2010
    390
    +25
    Is this a decent ssd or would I be better with a crucial m4?
  2. shadowboxer
    shadowboxer
    Mar 15, 2010
    1,572
    Staffordshire
    +197
    The Crucials are regarded very highly but it seems even they are not fail safe. Reports of failures hitting quite suddently at around 5200 hours of use.
    link here
    Crucial have annouced they are looking into it and will release a fix for them.
    The Corsair Force 3 had some eary teething problems but firmware updates seem to have resolved most issues.
    The F3's are bit cheaper, especially the 120GB+ ones so would get my vote.
    The most reliable ones seem to be Samsung and Intel drives at the moment.
  3. ArcAngel78
    ArcAngel78
    Jul 18, 2010
    390
    +25
    Ok thanks. Think I'll go with the 128gb corsair then.
