correcting zone selection for nuvo essentia
Discussion in 'Home Cinema Buying & Building' started by decardy, Feb 3, 2009.
  1. decardy
    decardy
    Oct 13, 2008
    29
    hi i have just purchased and installed a nuvo essentia music system,i have it up and running at the min but when i first powered it up the keypads asked for zone selection, but i must of got a couple mixed up cos a few keypads control speakers in a different room!!!i havent got the software to set it up right but is there anyway i can reset or select factory settings so i can choose the zones again??any help will be great
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    This is really a question for the supplying installer/dealer. Where did you buy from?
  3. decardy
    decardy
    Oct 13, 2008
    29
    i bought it in belfast n.i. i can ring them in the morning just thought there was an easy way out of it!!but i intend to get the software and install it properly when the house is completed.
  4. vex
    vex
    Mar 8, 2005
    2,905
    103
    London, Home Counties & North West
    +261
    The quick and dirty way would be to move the speaker outputs arround on the NuvoNet plate to match the zones you have set up.
    The proper way would be to do a factory reset by going into the advanced setting in the keypads.
    It is buried the manual somewhere, but here it is (from memory)
    Scroll through the keypad menus to settings, then down to advanced and it should be greyed out.
    Press and hold the OK key for about 6 - 10 seconds then this option will go live and in there you have a factory reset option.
    (Good aren't I)
    Hope that helps
    Not sure you will be able to get the installer only set up software though, which is why we do what we do.
    V.
  5. decardy
    decardy
    Oct 13, 2008
    29
    thats class,i wondered why i couldnt get into the advanced part of the menu.thanks vex, i will try this tomorrow and let you know!cheers:clap:
  6. decardy
    decardy
    Oct 13, 2008
    29
    vex, worked a treat!!!thanks again
  7. avbuzz
    avbuzz
    Feb 9, 2012
    2
  8. cjwood555
    cjwood555
    Jan 28, 2010
    1,376
    Solihull, West Midlands
    +110
    Too late but it's possible to move keypads around without doing a full reset. Involves going into the greyed out menus.
    Chris
