Correct Weights.
Discussion in 'Health & Fitness' started by DeAdSoUls, Aug 30, 2013.
  1. DeAdSoUls
    DeAdSoUls
    May 19, 2011
    523
    +22
    Is there a way to calculate which weight of dumbells to use? I'm doing dumbell bench presses.
  2. silent ninja
    silent ninja
    Mar 15, 2008
    3,028
    Coventry
    +825
    Yeah. Keep lifting heavier ones until you can't.
  3. Dextur
    Dextur
    Aug 30, 2004
    10,386
    +1,768
    If hypertrophy is your primary goal then an 6-10 rep range is optimal.
    Caveats abound, however this will suffice for most beginners.
    When you can perform 10 reps in perfect form, increase the weight until it becomes heavy enough to ensure , that, using perfect form, you can only manage 6 reps again.
    When you can again manage 10 reps in perfect form, you guessed it, it's time to increase the weight again.
    This process of slowly increasing the load /weight is called progressive resistance.
    In conjunction with periodization, progressive resistance is the cornerstone of any successful hypertrophy program.
    The above is adequate advice for quite some time until you significantly progress.
    By that I mean, until you can squat your own bodyweight at least 20 x and bench press it 10 x, you need to know very little more about rep ranges and load.
  4. Desmo
    Desmo
    Jan 4, 2001
    14,539
    Braintree, Essex.
    +6,618
    I think that perfectly sums up the short answer and the long answer :laugh:
  5. rjkgr
    rjkgr
    Aug 21, 2013
    165
    +6
    i weigh around 137 and i just lift 25lbs and maybe 20 to do 3 set of 20
  6. swiftpete
    swiftpete
    Sep 30, 2006
    5,156
    Notts
    +1,272
    25lbs dumbbells for 20 reps is too light. You'd be better off to increase the weight and drop the rep range. Do what Dextur recommends.
    My girlfriend weighs 100lbs and lifts 25lb dumbbells on dumbbell bench press by the way just to give you an idea of how light they are.
  7. leamspaceman
    leamspaceman
    Jun 22, 2004
    7,749
    +4,209
    Do some pyramids... 4x4.
    I'm up to 75kg x 4...30secs rest, 70kg x 4...30 secs rest, 65kg x 4...30 secs rest, 60 x 4.
    Obviously weight is split over two dumbells. Try floor press and pin presses too. They've both helped me alot.
  8. Desmo
    Desmo
    Jan 4, 2001
    14,539
    Braintree, Essex.
    +6,618
    I think that's getting a bit advanced. The guy is clearly a beginner and will be better off sticking to straight forward sets and reps, IMO of course.
  9. SteveCritten
    SteveCritten
    Aug 13, 2009
    10,914
    Caistor Lincs
    +4,564
    75kg dumbells is your name Arnie ;-).
  10. Desmo
    Desmo
    Jan 4, 2001
    14,539
    Braintree, Essex.
    +6,618
    He does say the weight is split over two dumbbells :p
  11. SteveCritten
    SteveCritten
    Aug 13, 2009
    10,914
    Caistor Lincs
    +4,564
    Even so still good lifting ;-)
  12. Desmo
    Desmo
    Jan 4, 2001
    14,539
    Braintree, Essex.
    +6,618
    It's decent, but not amazing. Plenty will use the 40+kg's and a few down our gym will happily bench using the 65kg db's.
  13. swiftpete
    swiftpete
    Sep 30, 2006
    5,156
    Notts
    +1,272
    The biggest in my gym are 42kg. I can press the 38s, so I'm getting there. It's not that far now before I'll be lifting the biggest dumbbells in the gym, it's not that great an achievement but it will be a small goal of mine!
    I'd be impressed if I saw someone using 65s.
  14. Desmo
    Desmo
    Jan 4, 2001
    14,539
    Braintree, Essex.
    +6,618
    I think ours top out at 75kg :eek:
