"Correct" way to Bi-Amp 2 P25's
Discussion in 'Arcam Owners' Forum' started by nickd01, Jun 21, 2005.
  1. nickd01
    nickd01
    Jun 20, 2005
    60
    What is the "correct" way to Bi-Amp??
    I have 2 P25's (1 2ch and 1 3ch) and in order to Bi-Amp my B&W CDM9NT's I've currently connected one amp to both low frequencies, and one to both high frequencies.
    Or, should I use one Amp per speaker?
    Or, should I use one Amp per low-frequency input and use my A25 (Which is currently solely used as a pre-amp) to drive both high frequencies? Would this mean the P25's are acting as a monobloc??
    Is there a recomended way? Or, is there a way that might blow everything up?!
    Nick
  2. OrangeHifi
    OrangeHifi
    Jun 19, 2005
    56
    Netherlands
    +3
    Bi-amping in the traditional way is that u use one amplifier to drive the high frequencies at both speakers and one amplifier for the low frequencies at both speakers. The way your configuration is now is the right way.
    It's necessarily that the amplifiers are gained for this, but with two P25's this is no problem because since a couple of yrs all the Arcam amplifiers are gained for bi-amping.
    When u drive one speaker with one amplifier and the other speaker also with one amplifier then this a monobloc configuration.
