correct connecting
Discussion in 'Cables & Switches' started by markeynon, Jul 18, 2004.
  1. markeynon
    markeynon
    TV--sony wega kv36hq100b
    AMP--pioneer vsx-c501
    DVD--pioneer dv-565a
    SPEAKERS--mission m7`s 5.1
    NTL--cable box
    just wanted to know the best way to connect the above together for best picture & sound
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    IF TV has component input use that for DVD otherwise RGB Scart RGB scart fo ntl TV analogue audio out from TV to amp, DVD audio to amp (coax or optical) speakers as manual
  3. markeynon
    markeynon
    at the mo i`ve got all the leads going into the av amp and 1 scart going to the tv from the amp.is this correct? the tele has 5 scarts,2 rgb,should i be using more of these direct from the components? ie dvd,cable box........
  4. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    transferring to cables & connections forum.
  5. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    I prefer to connect directly from the source to the TV for pictures as the less connections in the chain, the less degradation of the picture.
    I connect my digibox and DVD player directly to the TV by scart with audio connections to the amplifier. That way both benefit from RGB pictures without the inevitable degradation of routing it via the amp.
    You haven't mentioned a VCR but if you are using one that should also be connected directly to the Tv using one of the non RGB scarts on the TV
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    nothing wrong with what you are doing and it is more convienient. make sure you use digital for DVD sound though
  7. masif
    masif
    Jul 14, 2004
    11
    Hi Gentlemen,
    i am also about to setup my home cinema and the advice of Hornydragon sounds very useful, i have a similar setup:
    Panasonic Plasma TV TH37PE30B
    Sony DVD Player DVP-S336
    NTL Cable Box
    and in the process of purchasing a home cinema system.
    So if i've got this correct, i should connect the Component out from the Plasma to the DVD Component (if it has the connections). Audio (coaxial or optical) from the DVD to the AMP, RGB out from the Plasma to the NTL box, and the Audio out from TV to the AMP and speakers as normal?
    If this setup is correct, then i would also like advise on the type of cabling to use:
    Component
    Audio - coaxial/optical
    Scart RGB?
    Audio from TV to AMP
  8. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    exactly mate for TV(Panny tuner) to amp panny very nicely put audio outputs on on the polasma so a pair of analogue phono leads is needed.
