Corner mounting Plasms Screen
Discussion in 'Home Cinema Buying & Building' started by candg, Sep 8, 2003.
  1. candg
    candg
    I just bought a TH-42PW5 screen from Richersounds for £2599 So far very impressed with picture quality.
    My question is about corner mounting plasma screens. Is there anything on the market to allow this screen to be mounted in a corner. I know this must sound weird..but it,s the best configuration for the room it is in.
    Also I am looking to connect
    TIVO (via RGB)
    PC: for soundserver running from WiFi home network, home automation software, CCTV, and Internet.
    DVD (via component). What are my best options for maintaining maximum picture quality on all inputs.
    Any feedback greatly apreciated
    Graham Yeates
  2. mikeq
    mikeq
    Someone on here had a plasma on a bracket which could swing out, they had posted some piccies do a search to see if you can find it.
  3. jmack
    jmack
  4. jmack
    jmack
  5. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    Try handy andy's MDF, with a flat mount. The double swing out is a hell of a price, and shutting off the corner with a panel gives a place for the kit, cables, power sockets, etc. Could all be very neat.
