Cordless Mouse / Keyboard With Long Range
Discussion in 'Computer Peripherals & Consumables' started by blossom, Jan 13, 2005.
  1. blossom
    blossom
    Feb 15, 2004
    1,270
    41
    Solihull
    +15
    Hi Chaps,
    Can anybody recommend a Cordless Mouse and Keyboard with a range of approx 7-8 meters.
    Want to use with a screen in another room.
    Paul
  2. Kahless725
    Kahless725
    Mine is about 8 meters from the pc, I bought a normal usb corless keyboard and mouse and use 3 x 2m usb2 extension cables with the cordless kb and mouse reciever on the end in another room.
    Other way to go is get bluetooth with a 30 foot range.
  3. lisag
    lisag
    Jul 14, 2004
    5,993
    Essex
    +398
    Gyration have a very long range and works through walls, no line of sight requird, got mne from Maplin
  4. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    Gyration mouse is also great as it can be used waving it around in mid-air .. don't laugh, it's very easy to use and great when watching movies on an HTPC.
  5. blossom
    blossom
    Feb 15, 2004
    1,270
    41
    Solihull
    +15
    Sounds just the job. How much do they cost?
  6. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    There's the rub, not cheap, not sure that's the cheapest you'll get them but it's where I got mine.
