Thanks for the quick rsponse..define 'rip it' for me!! Do you mean it needs copying from media player first before putting it into your i-tunes library?
I've never had a problem with any CD and iTunes, apart from the ones that want to load some other software when you put the CD in. Just make sure you cancel the other software loading and they normally import fine..... unless I've just been lucky so far !
I have just loaded Kylie (for my wife honest) on sonicstage and a new player has popped up and started playing it and I can't transfer the songs.How can i get round this?
Scrapbook
Yes, exactly that. It's a bit of a longwinded way around the problem, but it works.
Newbie265,
Use windows media player to rip the CD, then import the tracks from there to sonicstage..... it worked for me.
