copying tv direct to my computer dvd rewriter
Discussion in 'Desktop & Laptop Computers Forum' started by john92, Jan 19, 2004.
  1. john92
    john92
    hello out there
    i want to know if there is anyway of writing dvd's of tv programmes directly using my computer.
    i expect there isn't i dont know.
    if anyone out there knows the answer to this question can you please tell me.
    from john93:confused:
  2. apul
    apul
    Jan 8, 2003
    689
    Durham
    +19
    yes, assuming u want to record freeview, get a digi card, like one from nebula, record the program and u can use writing software to burn it onto DVD.
    u'd be better asking the folks in the HTPC/computer forum, and i think there have been a few threafds about this and other methods on there, just do search in that forum
    maybe this post should be moved there? :confused:
  3. MarkE19
    MarkE19
    Aug 10, 2002
    17,335
    Rainham Essex
    +2,433
    Ulead DVD moviefactory 2 can write direct to a DVD.
    You will need to get an analogue capture device and feed it with the TV signal to be recorded. I am not sure if you will be able to use an internal TV tuner with this software or even if you can set timed recordings with it.
    Mark.
