Copying Sky Movies
Discussion in 'Blu-ray & DVD Players & Recorders' started by bigboper, Jul 26, 2004.
  1. bigboper
    bigboper
    Hi All, I am new to this AV Lark, so please bear with me. I have Sky Plus, and would like to be able to record the Sky Movies (not the premium channels) on to DVD to watch at my leisure.
    If I buy a DVD recorder is this possible? Or are the films encoded?
    Also can anyone recommend a DVD recorder that won't break the bank, ie Sub £200, or is this price being unrealistic. Thanks all.
  2. phelings
    phelings
    Jul 24, 2003
    1,025
    36
    If you buy a Pioneer you will have to spend about £250,but this will offer -RW so you will be able to record your movies,watch in another player if you want,then erase and reuse.If you go Panasonic you will be able to do the same as long as your recordings are watched ONLY on the recorder(as RAM is not compatible with other players)or you want to keep the movies in which case you use write once -R which IS compatible.Avoid DVD+ machines as their functionality is PRIMITIVE and their reliability ,and quality are questionable.
  3. Kwozzii
    Kwozzii
    Jun 29, 2003
    295
    Northants
    +16
    I copy movies to a Panasonic E85 as I watch them and copy them to dvd if I like 'em no problem.........
    Kwozzii
