Quantcast
Copying SACD's?
mobily
Hello all,
Is it possible to copy SACD's as you would a normal CD or is it not possible?
Thanks,
James :)
MartinImber
No
gringottsdirect
If it is a hybrid SA-CD with normal CD layer you can use this.
Alternatively you may wish to use the analogue output from your SA-CD player to make analogue copies onto CD-R , Minidisc or whatever.
Copyright legislation notwithstanding. :)
