Copying/Pasting clips in Adobe Premiere
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by Makaveli96, Jul 17, 2005.
  1. Makaveli96
    Makaveli96
    Hi. I'm having trouble copying and pasting a series of clips in Premiere. When I select several clips and I right click to choose copy, all except one of the clips I selected gets deselected. I tried selecting the clips and going to edit, but the "copy" command is deactivated. I only know how to copy and paste a single clip. Can someone tell me how to copy and paste a series of clips at the same time? Thanks.
  2. Makaveli96
    Makaveli96
    No one knows???
  3. roysboys
    roysboys
    In all versions you can:
    1. save your project
    2. open a new project
    3. import the old project (as a project) and drag it onto your timeline as many times as you want.
    Thats one way of doing it though I dont know whether that will be what your after.
  4. Makaveli96
    Makaveli96
    No, what I want to do is highlight some clips on my timeline and then paste them somewhere else on the timeline. Not just copy and paste each clip individually.
  5. MarkE19
    MarkE19
    Aug 10, 2002
    17,259
    Rainham Essex
    +2,403
    If all the required clips are in the 'project bin' then you can drag them onto the timeline as many times as they are required, although I think you can only drag them one at a time.
    Mark.
