Copying Humax Foxsat-HDR files to new HDR-11005
Outoftown
My original Humax Foxsat HDR recorder was playing up (remote control issues). I now have the new Humax with 1T of storage. Is it possible to transfer, or archive my earlier recorded programmes? I was under the impression I could either convert the earlier recordings or transfer via an external Hard Drive? Both have USB Ports.
grahamlthompson
In memoriam
Unless you have the Custom Firmware and Nowsters patch, you can only transfer SD recordings. The USB drive will need to formatted FAT32 (max file size 4GB) or EXT3. You only need the .ts files, the freetime boxes don't recognise the other support files. If you install the CF you can copy the, directly to a PC if the Foxsat is connected to your home network. HD recordings won't work because they are encrypted.
