Copying from sky+ to panasonic Hdd dmr ex83
chiyaan
I have bought a new panasonic HDD recorder dmr ex83. I want to copy some of my recordings from sky+ box. I have tried scart to scart connection and tried to copy but it is not working. Panasonic manual is too complex.
any help appreciated
Stevenage Neil
You have to set the Panasonic input to the Scart connection, normally AV1 or AV2.
logiciel
Play a programme on the Sky receiver - no need to use the Copy option.
Power on the recorder.
Change the TV input to the one used for the recorder.
Set the recorder's input to the one used for the Sky receiver, as S N said.
You should see the programme that you set to play.
If you do see it, press Record.
If not, let us know.
chiyaan
Thanks logiciel. That worked. But the picture quality seems to be slightly different. I will see if I can record it in a different mode.
Broadz
Only one scart socket on a Sky+ box is RGB enabled (the one marked TV). So, if you have the one marked TV going into the TV, with RGB switched on, and you have the one marked VCR (which is composite only) going into the DVDR, you will notice a difference in pic quality between the TV and the DVDR. Namely, the TV will be better.
logiciel
That's OK, do use the Sky RGB Scart, and try the different levels of recording quality, XP, SP, and LP, rather than Flexible.
chiyaan
Is there any way I could copy from Sky+ to HDD without actually playing it( i.e. something akin to copying files to an usb ).
I have got programmes about 6 hours long which I need to copy.
logiciel
Yes.
logiciel
Snap. Now it's your turn Broadz.
