Copying from humax Foxsat to Fox-T2??
Sor
I have a number of programmes copied onto a portable hard drive from my foxsat. My phd has linux and windows partitions.
I tried last night for the first time to copy these onto my fox-T2. (Actually I copied some programmes into the linux partition first as I had nothing in there).
Initially the Fox-t2 did see the files but when I selected copy, I'm not sure what happened.... or at least nothing seemed to happen. They didn't get copied to the HDD. Then the Fox-T2 decided not to see the files on my phd (which were still there as I checked on my foxsat).
I decided to remove the programmes from the phd and copy across a new (different) set of files from my foxsat. The fox t-2 still told me there were 2 files in the drive1 but could not actually see them - nothing came up on screen for me to copy and if i copy the folder, there is nothing in it.
The fox-t2 can see my 2nd partition (windows) and can copy folders across (I accidently did a 'copy all' when the phd was plugged in, but didn't really expect documents to display!) It did manage to copy across some .avi and these are now on the fox-t2 and can be played from there.
Any suggestions on how I've managed to 'hide' these other files now? They should be .ts so I was assuming there really should not be anything difficult about this process..........Though since copy didn't work the first time, is there something particularly obvious that I didn't do?!
I'll switch everything of at the wall and have a look at my phd partitions on my pc later on, delete everything and start again and see if I get better results.
But any helpful suggestions would be great.
Many thanks.
grahamlthompson
Sor
Thanks Graham,
I'll have a play this evening with this. :)
Podcast: Reported HDMI 2.1 bugs, Audiolab Amp & LG LED Projector reviews + Best of the Month
