Copying from DVD RAM
Discussion in 'Blu-ray & DVD Players & Recorders' started by bertJ, Oct 16, 2004.
  1. bertJ
    bertJ
    May 13, 2004
    27
    I'm thinking of buying a Panasonic S35 or similar to play DVD RAM disks I've recorded and edited on my Panasonic DMR-E55EB. I want to copy the edited DVD RAM disk to a CD-R disk. I'm new to DVD editing and copying but have learnt a lot from experts on this forum. However (and this is probably a stupid question) do DVD RAM disks have to be finalised before they will play on a Panasonic S35 or any other DVD RAM compatible player?
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,710
    Warwick
    +2,585
    No finalisation is necessary - if the player reads DVD-RAMs (as the S35 does) they play.
    You appreciate the S35 and E55 can't do this don't you? You'll need to use a PC and a programme such as TMPG Enc 3Xpress to achieve this. However burning to CD will never give very results - you'd be better off getting yourself a DVD burner (you can pick them up for under £50) and burn to DVD-R.
  3. bertJ
    bertJ
    May 13, 2004
    27
    Sorry - I didn't make things very clear. I want to copy the CD RAM disk to CD-R by linking the S35 to my DMR-E55. I intend playing the CD-RAM in the S35 and copying it to the CD-R in the DMR-E55.
  4. jerryq7777
    jerryq7777
    Sep 28, 2004
    4,300
    +677
    Eh ? :laugh:
    Are you using cd-r 700 MB or dvd-r 4.7 GB ?
  5. bertJ
    bertJ
    May 13, 2004
    27
    Sorry again - I'm going mad! I am, of course, using DVD-RAM and DVD-R.
  6. Archie Fax
    Archie Fax
    Nov 23, 2003
    233
    Kent
    +10
    This is off topic but a nice feature of the e55 is you can change the units remote control code (instruction manual page 15) so that you can use 2 panasonic dvd machines in the same room independantly. The e55's remote control will then only operate the e55 without affecting the the other dvd player.
    I've never copied anything as yet myself though.
