Copying a hard disk
Discussion in 'Desktop & Laptop Computers Forum' started by snejk, Mar 23, 2006.
  1. snejk
    snejk
    I have an 80gig hard disk and i want to upgrade to a 160gig hd. If i copy paste all the contents of my current hard disk to the new hard disk will i be able to boot up with my new hard disk the next time i start my computer and will every else be the same (just more free disk space :) ) ??
  2. deksawyer
    deksawyer
    May 26, 2005
    1,641
    Fife, Scotland
    +132
    No, it doesn't work like that I'm afraid.
    You'll need to clone your existing drive as some sort of backup, using Norton Ghost for example, and use that to trasfer it over to the new drive or use the transfer wizard built into XP, if that's what you're using.
    Or even better, leave your boot drive as it is and just add the bigger drive as a secondary slave.
    D.
  3. Uridium
    Uridium
    Jan 29, 2005
    14,434
    North West Leicestershire
    +1,855
    Most HDU manafacturers have a free App downloadable from their websites allowing Disk imaging from current drive to new drive. check the HDU makers website.
    Maxblast for example is one for Maxtor drives
